ADI ADSP-CM403F EZ-KIT Lite评估方案
关键词:工业控制 马达控制 太阳能 太阳能逆变器
时间:2013-10-15 10:43:48       作者:ADI       来源:中电网
ADI 公司的ADSP-CM403F是基于ARM® Cortex-M4TM内核的具有浮点运算的处理器,工作频率高达240MHz,集成了高达384KB的SRAM存储器,2MB闪存,两个16位SAR类型的ADC和两个12位DAC,加速器和外设.器件工作于单一电压,主要用于马达控制和光伏电压(PV)逆变器控制.本文介绍了ADSP-CM403F主要特性,框图,模拟子系统框图以及ADSP-CM403F EZ-KIT Lite评估板主要特性,电路图和材料清单.
Based on the ARM® Cortex-M4TM processor core with floating point unit operating at frequencies up to 240 MHz and integrating up to 384KB of SRAM memory, 2MB of flash memory, accelerators and peripherals optimized for motor control and photo-voltaic (PV) inverter control and an analog module consisting of two 16-bit SAR-type ADCs and two 12-bit DACs. The ADSP-CM40x family operates from a single voltage supply(VDD_EXT/VDD_ANA), generating its own internal voltage supplies using internal voltage regulators and an external pass transistor.
This family of mixed-signal control processors offers low static power consumption and is produced with a low-power and low voltage design methodology, delivering world class processor and ADC performance with lower power consumption.
查看全文
