IR IRS27951 220W开关电源解决方案
关键词:电源管理 AC/DC转换器 DC/DC转换器
时间:2011-11-21 11:44:12       作者:IR       来源:IRS27951
IR公司的IRS27951/2是自振荡半桥驱动IC,每路的最大工作频率500kHz,占空比50%,工作电压高达+600VDC,可编程最小和最大开关频率,可编程软起动频率和软起动时间和死区时间,提供过流保护,欠压锁住,主要用在LCD和PDP TV,通信开关电源,PC开关电源和家庭音频系统.本文介绍了IRS27951/2主要特性, 功能方框图,典型应用电路以及220W评估板IRAC27951主要指标,电路图,材料清单和PCB布局图.
The IRS2795(1,2) is a self oscillating half-bridge driver IC for DC-DC resonant converter applications, especially the LLC resonant half-bridge converter. The frequency and dead time can be programmed externally using two external components. The IC offers over current protection using the on state resistance of the low-side MOSFET. The IC can be disabled by externally pulling the voltage at the CT/SD pin below its enable voltage threshold.
IRS27951/2主要特性:
· Simple primary-side control solution for fixed and variable frequency DC-DC resonant converters.
· Max 500kHz per channel output with 50% duty cycle
· Floating channel bootstrap operation up to +600Vdc
· Programmable minimum and maximum switching frequency
· Programmable soft start frequency and soft start time
· Programmable dead time
· Micropower start-up & ultra low quiescent current
查看全文
