TI公司的TIDA-01604是效率98.6% 6.6kW图腾柱无桥功功率因素校正(PFC)参考设计.功率级有C2000™微控制器(MCU)和SiC隔离的栅极驱动器所驱动的碳化硅(SiC) MOSFET.参考设计实施是三相交错的,工作在连续导通模式(CCM),在240V输入电压和6.6kW满功率时效率达到98.6%,C2000控制器赋能切相和自适应死区控制,以改善轻负载时的功率因素.栅极驱动器板具有增强隔离特性,能经受大于100V/ns共模瞬态抗扰度(CMTI).栅极驱动器还包含两级关断电路,可保护MOSFET在短路情况下免受电压过充的损害.可编输出电压400V到600V.主要用在HEV/EV牵引逆变器,HEV/EV板上充电器,汽车电控制单元,HEV/EV DC/DC转换器.本文介绍了参考设计TIDA-01604主要特性和系统指标,框图,电路图,材料清单和PCB设计图.
This reference design presents a 6.6-kW totem-pole(TTPL) bridgeless power factor correction (PFC)solution for Onboard Charger. The power stageimplements silicon carbide (SiC) MOSFETs driven bya C2000™ microcontroller (MCU) with SiC-isolatedgate drivers. The design implements three-phaseinterleaving and operates in continuous conductionmode (CCM) to achieve a 98.60% efficiency at a 240-V input voltage and 6.6-kW full power. The C2000controller enables phase shedding and adaptive deadtime
control to improve the power factor at light load.
The gate driver board (see TIDA-01605) implementsreinforced isolation and can withstand more than 100-V/ns common-mode transient immunity (CMTI). Thegate driver board also contains the two-level turnoffcircuit, which protects the MOSFET from voltage
overshoot during the short-circuit scenario.
参考设计TIDA-01604主要特性:
• High-power-density, high-efficiency PFC design topower systems up to 6.6 kW
• SiC MOSFETs with TI drivers offers higherintegration for customers
• Half-bridge- and compact isolated gate driver withreinforced isolation and two-level turnoff protection
• Full digital control with high-performance C2000™controller to enable advanced control scheme
• 98.86% peak efficiency, greater than 0.99 powerfactor and less than 2% total harmonic distortion(THD)
• Three-phase interleaved operation with phaseshedding control
• Programmable output voltage of 400 V to 600 V
参考设计TIDA-01604应用:
• HEV/EV Traction Inverter
• HEV/EV Onboard Charger
• Electronic Control Units
• HEV/EV DC/DC Converters
图1.参考设计TIDA-01604外形图
图2.参考设计TIDA-01604框图
参考设计TIDA-01604主要系统指标:
图3.参考设计IDA-01604电路图(1)
图4.参考设计TIDA-01604电路图(2)
参考设计TIDA-01604材料清单:
图5.参考设计TIDA-01604 PCB设计图(1)
图6.参考设计TIDA-01604 PCB设计图(2)
图7.参考设计TIDA-01604 PCB设计图(3)
图8.参考设计TIDA-01604 PCB设计图(4)
图9.参考设计TIDA-01604 PCB设计图(5)
图10.参考设计TIDA-01604 PCB设计图(6)
图11.参考设计TIDA-01604 PCB设计图(7)
图12.参考设计TIDA-01604 PCB设计图(8)
图13.参考设计TIDA-01604 PCB设计图(9)
图14.参考设计TIDA-01604 PCB设计图(10)
图15.参考设计TIDA-01604 PCB设计图(11)
图16.参考设计TIDA-01604 PCB设计图(12)
详情请见:
和
以及
和
中电网 中国电子行业研发工程师一站式服务平台
关于中电网| 广告招商| 联系我们| 招聘信息| 友情链接| 中电网导航| 电子标签大全| 手机中电网 | 中电网官方微博
Copyright © 2000- 中电网 版权所有 粤ICP备17063136号-2 增值电信业务经营许可证粤B2-20050142 公安机关备案号44030402002188
